iPod Touch 7th Generation Lightning Connector Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPod Touch 7th Generation Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 1, image 1 of 1
      • Use the tip of a spudger to peel back a small piece of tape covering a screw on the left side of the headphone jack.
      Ask FixBot
    2. iPod Touch 7th Generation Lightning Connector Assembly Replacement: step 2, image 1 of 1
      • Remove the following screws securing the headphone jack, Lightning connector, and speaker.
      • Three 2.6 mm #000 Phillips screws
      • Two 2.0 mm #000 Phillips screws
      • One 1.85 mm #000 Phillips screw
      Ask FixBot
    3. iPod Touch 7th Generation Lightning Connector Assembly Replacement: step 3, image 1 of 1
      • Use the flat end of a spudger to pry the speaker up from the rear case.
      • Do not try to remove the speaker, as it is soldered to the Lightning connector assembly.
      Ask FixBot
    4. iPod Touch 7th Generation Lightning Connector Assembly Replacement: step 4, image 1 of 2 iPod Touch 7th Generation Lightning Connector Assembly Replacement: step 4, image 2 of 2
      • Grasping the large ribbon cable, gently pull the Lightning connector assembly out of the bottom of the case.
      Ask FixBot
Tarun Thiruma
40,755 Reputation
133 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 261
