iPod Touch 5th Generation Rear-Facing Camera Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 1 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 2 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: step 1, image 3 of 3
      • Insert the flat end of a spudger between the rear-facing camera and its frame.
      • Gently twist the spudger to free the camera.
      • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
      Ask FixBot
    2. iPod Touch 5th Generation Rear-Facing Camera Replacement: step 2, image 1 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 2, image 2 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 2, image 3 of 3
      • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
      • Run the spudger along the full length of the tape to disconnect it from the rear case.
      Ask FixBot
    3. iPod Touch 5th Generation Rear-Facing Camera Replacement: step 3, image 1 of 2 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 3, image 2 of 2
      • Peel and remove the foam tape from the rear case of the iPod.
      Ask FixBot
    4. iPod Touch 5th Generation Rear-Facing Camera Replacement: step 4, image 1 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 4, image 2 of 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
      • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
      Ask FixBot
Andrew Optimus Goldheart
515,900 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 400
