iMac Intel 20" EMC 2133 and 2210 RAM Replacement
Views: 112K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
152
All Time:
112,011
Comments: 19
7 comments on steps, 12 guide comments.
Go to guide comments
Completed: 164
164 people have marked this guide "completed." Will you be next?
Favorites: 55
55 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Upgrade your RAM for an instant increase in speed.
EMC 2133 models use PC2-5300 RAM and EMC 2210 models use PC2-6400 RAM. The maximum RAM for both models is 6 GB.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. iMac Intel 20" EMC 2133 and 2210 RAM Replacement, Access Door: step 1, image 1 of 1
      • Loosen the single Phillips screw in the center of the access door.
      • This screw is captive in the access door.
      • Remove the access door from your iMac.
      Ask FixBot
    1. iMac Intel 20" EMC 2133 and 2210 RAM Replacement, RAM: step 2, image 1 of 2 iMac Intel 20" EMC 2133 and 2210 RAM Replacement, RAM: step 2, image 2 of 2
      • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
      • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
      Ask FixBot
    2. iMac Intel 20" EMC 2133 and 2210 RAM Replacement: step 3, image 1 of 1
      • Grab the RAM chip by its edges and pull it straight out of its slot.
      • If two RAM chips are installed, repeat this process for the other chip.
      Ask FixBot
164 other people completed this guide.
12 Guide Comments
I currently have a 4GB memory module installed on an EMC 2210 in one of the memory slots. Can I still install the original 1GB ram in the other slot making it 5GB total memory?
richt0812 - Reply Share
[|It depends on the model. Check here:] https://support.apple.com/en-us/HT201191
Alex Nos - Reply Share
I installed 2GB x2 to mine to upgrade from 1GB x2. It took just minutes and I used a regular philips screw driver I found around home. Pull hard on the black straps to get the memory out. It is working great with no problems. Good luck!
1tom2go - Reply Share
Thank you for the guide. I had 2GB. I took out 1 module to add a 4GB module. So easy and now my 2133 iMac is jaw dropping fast.
Garison
garison - Reply Share
Hi Garison,
I hope you can answer my question. I have an iMac, medio 2007, Intel 20" EMC 2133.
RAM: (1GB + 1GB) 667 MHz DDR2 SDRAM.
I would like to make my iMac "jaw dropping fast" as well ;-)
Is it PC 5300 or PC 6400 I should buy?
And what setup wold you recommend? (1GB + 2GB), (1GB + 4GB), (2GB + 2GB) or (2GB + 4GB)?
Thanks,
Mikkel
mipedersen - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 152
All Time: 112,011
