Introduction
Battery not lasting long? Swap it out (requires soldering).
Insert the small plastic opening tool into the seam in between plastic display panel and the metal back panel. The angled edge should point towards the metal back panel.
Hold the tool in place once it is wedged inside and the two panels are separated.
Insert the large opening tool into the right side of the iPod, with the edge of the tool pointing towards the metal back.
Gently enlarge the existing crevice by wiggling the large opening tool and moving it to the right.
Continue doing so until the right side of the iPod is loose.
Switch to the other side of the iPod.
Follow the same procedure as in the previous step to release the seven clips holding the panels in place.
Once the panels are separated on this side, the back panel can be separated from the rest of the iPod.
Gently lift the rear panel using your fingers.
The front and back of the iPod should now be completely separated.
Flip the iPod 180 degrees so it matches the orientation in the picture.
Carefully insert the spudger in between the battery and the display. There are routing cables underneath, so make sure you slowly pry the battery loose.
Use a spudger (or your fingernails) to remove the gold antenna. The antenna bends easily, so make sure not to apply too much pressure. When re-assembling, put the gold antenna in place before inserting the antenna circuit boards.
Use the spudger to remove the connector on the left side.
Remove two Phillips screws.
The antenna loop board needs to be pried up (it is glued down). Gently use a plastic opening tool or spudger, to dislodge the antenna loop board. The board is connected to the antenna electronics by a small ribbon cable. This two-board assembly is very frail.
The two small antenna circuit boards can now be lifted up together, and their orange cable can be peeled from the display.
Use the spudger to remove the black masking tape. This will reveal the top two screws in the picture.
Unscrew the four Phillips screws.
Use a spudger to disconnect the black connector.
Use the spudger to loosen the logic board from multiple sides. It is held in place by glue and the four screws that were removed in the previous step.
Gently lift the logic board (and attached components) upward.
Slide the spudger under the small portion of the logic board. The board should come loose once the spudger has slid almost all the way to the other side.
Use the tip of a spudger to remove the cloudy white glue covering the battery contacts.
Clean the soldering iron by melting a small amount of solder directly onto the soldering iron's tip and then wiping the tip of the soldering iron on a damp sponge.
Place the desoldering wick on top of the existing solder ball.
Place the soldering iron on top of wick above the existing solder ball.
Hold the soldering iron in place until the solder melts into the wick.
Repeat the same procedure on the remaining two connectors.
Lift the old battery out of the iPod. Be sure that all the solder has been removed before pulling the wires away from the board. The wires should come free with little to no resistance.
Melt a small solder bead directly onto the metal connector on the board by placing the soldering iron onto the metal connector and then pressing solder against the tip and the board.
Once a small amount of solder has melted onto the board, lift the solder away first and then the soldering iron.
Place the wire from the new battery onto the new solder bead.
Press the tip of the soldering iron onto the solder bead until it melts.
Slide the wire lead into the liquid solder until the wire goes through the center of the bead, then remove the soldering iron.
Continue with the other two connections the same way, taking special care not to solder two of the connectors together.
