Installing iPod Shuffle 4th Generation Rear Panel
  1. Installing iPod Shuffle 4th Generation Rear Panel, Rear Panel: step 1, image 1 of 1
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage of some sort.
    • Before proceeding, be sure your Shuffle is switched off.
  2. Installing iPod Shuffle 4th Generation Rear Panel: step 2, image 1 of 2 Installing iPod Shuffle 4th Generation Rear Panel: step 2, image 2 of 2
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
  3. Installing iPod Shuffle 4th Generation Rear Panel: step 3, image 1 of 1
    • Remove the rear panel from the Shuffle.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 9,526
