Installing iPod Shuffle 4th Generation Logic Board Assembly
  1. Installing iPod Shuffle 4th Generation Logic Board Assembly, Rear Panel: step 1, image 1 of 1
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 2, image 1 of 2 Installing iPod Shuffle 4th Generation Logic Board Assembly: step 2, image 2 of 2
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
  3. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 3, image 1 of 1
    • Remove the rear panel from the Shuffle.
  4. Installing iPod Shuffle 4th Generation Logic Board Assembly, Logic Board Assembly: step 4, image 1 of 1
    • If present, remove the thin black moisture seal covering the Shuffle's internals.
    • Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
  5. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 5, image 1 of 2 Installing iPod Shuffle 4th Generation Logic Board Assembly: step 5, image 2 of 2
    • Use the edge of an iPod opening tool to flip up the retaining flap on the control button cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use a pair of tweezers to gently pull the control button ribbon cable out of its socket.
  6. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 6, image 1 of 2 Installing iPod Shuffle 4th Generation Logic Board Assembly: step 6, image 2 of 2
    • Use an iPod opening tool to gently pry the battery off the adhesive securing it to the front case.
    • Lift the battery out of the front case, being sure not to strain its delicate leads.
  7. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 7, image 1 of 2 Installing iPod Shuffle 4th Generation Logic Board Assembly: step 7, image 2 of 2
    • Insert the tip of a metal probe into the hole molded into the logic board retainer nearest the logic board.
    • Pry the retainer first away from the front of the front case, then pull it away from the side of the front case.
    • Remove the logic board retainer from the Shuffle.
  8. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 8, image 1 of 2 Installing iPod Shuffle 4th Generation Logic Board Assembly: step 8, image 2 of 2
    • Use the edge of an iPod opening tool to push the headphone jack down toward the center of the Shuffle.
  9. Installing iPod Shuffle 4th Generation Logic Board Assembly: step 9, image 1 of 2 Installing iPod Shuffle 4th Generation Logic Board Assembly: step 9, image 2 of 2
    • Continue pushing the logic board down away from the top edge of the Shuffle.
    • Pull the logic board out of the front case by the side nearest the ON/OFF button and gently maneuver the headphone jack out of its recess in the front case.
    • Remove the logic board assembly from the Shuffle.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 46
All Time: 14,014
