Installing iPod Shuffle 3rd Generation Rear Case
  1. Installing iPod Shuffle 3rd Generation Rear Case, Rear Case: step 1, image 1 of 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap towards the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. Installing iPod Shuffle 3rd Generation Rear Case: step 2, image 1 of 2 Installing iPod Shuffle 3rd Generation Rear Case: step 2, image 2 of 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. Installing iPod Shuffle 3rd Generation Rear Case: step 3, image 1 of 1
    • Insert the opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. Installing iPod Shuffle 3rd Generation Rear Case: step 4, image 1 of 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
Matthew Newsom
39,527 Reputation
67 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 33
All Time: 8,114
