Installing iPod Shuffle 2nd Generation Logic Board Assembly
  1. Installing iPod Shuffle 2nd Generation Logic Board Assembly, Logic Board Assembly: step 1, image 1 of 1
    • Before beginning, be sure your Shuffle is turned off as shown.
  2. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 2, image 1 of 2 Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 2, image 2 of 2
    • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
    • Remove the plastic cover and set it aside.
  3. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 3, image 1 of 1
    • Remove the two Phillips screws from the headphone jack side of the Shuffle.
  4. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 4, image 1 of 2 Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 4, image 2 of 2
    • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
  5. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 5, image 1 of 2 Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 5, image 2 of 2
    • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
  6. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 6, image 1 of 2 Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 6, image 2 of 2
    • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
  7. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 7, image 1 of 1
    • Remove the two Phillips screws on the controls side of the Shuffle.
  8. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 8, image 1 of 2 Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 8, image 2 of 2
    • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
  9. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 9, image 1 of 1
    • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
  10. Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 10, image 1 of 2 Installing iPod Shuffle 2nd Generation Logic Board Assembly: step 10, image 2 of 2
    • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
    • Pull the logic board assembly out of the outer case.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 44
All Time: 19,026
