iPod Nano 7th Generation Front Panel Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPod Nano 7th Generation Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 2
    • Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
  2. iPod Nano 7th Generation Front Panel Assembly Replacement: step 2, image 1 of 3 iPod Nano 7th Generation Front Panel Assembly Replacement: step 2, image 2 of 3 iPod Nano 7th Generation Front Panel Assembly Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
    • Insert a spudger under the cover, then pry it up and away from the device.
    • Remove the rear plastic cover from the iPod.
  3. iPod Nano 7th Generation Front Panel Assembly Replacement: step 3, image 1 of 1
    • Gently bend the Bluetooth antenna to the right, out of the way of the screws in the bottom of the device.
    • Remove the single 1.4 mm Phillips #000 screw from the black plastic spacer.
  4. iPod Nano 7th Generation Front Panel Assembly Replacement: step 4, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to remove the black plastic spacer from the Nano.
  5. iPod Nano 7th Generation Front Panel Assembly Replacement: step 5, image 1 of 1
    • Remove the two 2 mm Phillips #000 screws from the bottom of the case.
  6. iPod Nano 7th Generation Front Panel Assembly Replacement: step 6, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement: step 6, image 2 of 2
    • Insert a plastic opening tool into the seam between the white plastic front panel and the rear case.
    • Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
  7. iPod Nano 7th Generation Front Panel Assembly Replacement: step 7, image 1 of 1
    • Use a spudger to press the midframe screw tab up and out of the rear case.
  8. iPod Nano 7th Generation Front Panel Assembly Replacement: step 8, image 1 of 1
    • Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
    • The adhesive under the metal midframe/display assembly is quite strong and the components are fragile, so go slowly and gently.
  9. iPod Nano 7th Generation Front Panel Assembly Replacement: step 9, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement: step 9, image 2 of 2
    • Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
  10. iPod Nano 7th Generation Front Panel Assembly Replacement: step 10, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement: step 10, image 2 of 2
    • Pull the front panel assembly slightly down and partially out of the device.
    • You only need to open the device enough to gain access to the display cable connectors near the sleep/power button.
    • Do not separate the two halves entirely, they are still connected by several cables.
  11. iPod Nano 7th Generation Front Panel Assembly Replacement: step 11, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement: step 11, image 2 of 2
    • Use a spudger to release the digitizer cable and display data cable connectors.
  12. iPod Nano 7th Generation Front Panel Assembly Replacement: step 12, image 1 of 1
    • Gently unfold the two halves of the device to access the internal components.
    • Do not try to completely separate the two sections, yet, as they are still attached via a soldered cable.
  13. iPod Nano 7th Generation Front Panel Assembly Replacement: step 13, image 1 of 2 iPod Nano 7th Generation Front Panel Assembly Replacement: step 13, image 2 of 2
    • Pull up on the battery pull tab to free the battery from its adhesive.
    • Flip the battery over into the rear case for safekeeping.
  14. iPod Nano 7th Generation Front Panel Assembly Replacement: step 14, image 1 of 1
    • Completely separate the front panel assembly from the rest of the device.
Sam Goldheart
466,490 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 159
