Replacing iPod Nano 7th Generation Display
  1. Replacing iPod Nano 7th Generation Display, iOpener Instructions: step 1, image 1 of 3 Replacing iPod Nano 7th Generation Display, iOpener Instructions: step 1, image 2 of 3 Replacing iPod Nano 7th Generation Display, iOpener Instructions: step 1, image 3 of 3
    • Place the iOpener in the microwave and heat it for one minute on the highest power setting.
    • Be careful not to overheat the iOpener during the repair procedure.
    • If you have not used your iOpener for some time, or this is the first time you are using the iOpener, microwave it wrapped in a damp paper towel. This will prevent it from burning if it is overheated.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
  2. Replacing iPod Nano 7th Generation Display: step 2, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the corners.
    • The bag will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  3. Replacing iPod Nano 7th Generation Display, Front Panel Assembly: step 3, image 1 of 2 Replacing iPod Nano 7th Generation Display, Front Panel Assembly: step 3, image 2 of 2
    • Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
  4. Replacing iPod Nano 7th Generation Display: step 4, image 1 of 3 Replacing iPod Nano 7th Generation Display: step 4, image 2 of 3 Replacing iPod Nano 7th Generation Display: step 4, image 3 of 3
    • Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
    • Insert a spudger under the cover, then pry it up and away from the device.
    • Remove the rear plastic cover from the iPod.
    • Be very careful in removing the plastic cover as the bluetooth antenna is adhered to it.
  5. Replacing iPod Nano 7th Generation Display: step 5, image 1 of 1
    • Gently bend the Bluetooth antenna to the right, out of the way of the screws in the bottom of the device.
    • Remove the single 1.4 mm Phillips #000 screw from the black plastic spacer.
  6. Replacing iPod Nano 7th Generation Display: step 6, image 1 of 2 Replacing iPod Nano 7th Generation Display: step 6, image 2 of 2
    • Use a plastic opening tool to remove the black plastic spacer from the Nano.
  7. Replacing iPod Nano 7th Generation Display: step 7, image 1 of 1
    • Remove the two 2 mm Phillips #000 screws from the bottom of the case.
  8. Replacing iPod Nano 7th Generation Display: step 8, image 1 of 2 Replacing iPod Nano 7th Generation Display: step 8, image 2 of 2
    • Insert a plastic opening tool into the seam between the white plastic front panel and the rear case.
    • Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
  9. Replacing iPod Nano 7th Generation Display: step 9, image 1 of 1
    • Use a spudger to press the midframe screw tab up and out of the rear case.
  10. Replacing iPod Nano 7th Generation Display: step 10, image 1 of 1
    • Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
    • The adhesive under the metal midframe/display assembly is quite strong and the components are fragile, so go slowly and gently. Make sure you do not bend the LCD screen.
  11. Replacing iPod Nano 7th Generation Display: step 11, image 1 of 2 Replacing iPod Nano 7th Generation Display: step 11, image 2 of 2
    • Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
  12. Replacing iPod Nano 7th Generation Display: step 12, image 1 of 2 Replacing iPod Nano 7th Generation Display: step 12, image 2 of 2
    • Pull the front panel assembly slightly down and partially out of the device.
    • You only need to open the device enough to gain access to the display cable connectors near the sleep/power button.
    • Do not separate the two halves entirely, they are still connected by several cables.
  13. Replacing iPod Nano 7th Generation Display: step 13, image 1 of 2 Replacing iPod Nano 7th Generation Display: step 13, image 2 of 2
    • Use a spudger to release the digitizer cable and display data cable connectors.
  14. Replacing iPod Nano 7th Generation Display: step 14, image 1 of 1
    • Gently unfold the two halves of the device to access the internal components.
    • Do not try to completely separate the two sections, yet, as they are still attached via a soldered cable.
  15. Replacing iPod Nano 7th Generation Display: step 15, image 1 of 2 Replacing iPod Nano 7th Generation Display: step 15, image 2 of 2
    • Pull up on the battery pull tab to free the battery from its adhesive.
    • Flip the battery over into the rear case for safekeeping.
  16. Replacing iPod Nano 7th Generation Display: step 16, image 1 of 1
    • Completely separate the front panel assembly from the rest of the device.
  17. Replacing iPod Nano 7th Generation Display, Display Assembly: step 17, image 1 of 2 Replacing iPod Nano 7th Generation Display, Display Assembly: step 17, image 2 of 2
    • Insert a spudger under the metal midframe and display on the left side of the home button.
    • Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
    • Rotate the spudger around the home button and across the front panel, releasing the adhesive holding the display in place.
  18. Replacing iPod Nano 7th Generation Display: step 18, image 1 of 1
    • Once all of the adhesive has been released, gently separate the display assembly from the front glass/digitizer.
  19. Replacing iPod Nano 7th Generation Display, Display: step 19, image 1 of 2 Replacing iPod Nano 7th Generation Display, Display: step 19, image 2 of 2
    • Remove the six (three on each side) 1.5 mm Phillips #000 screws securing the metal midframe to the display.
  20. Replacing iPod Nano 7th Generation Display: step 20, image 1 of 1
    • If there is tape holding the midframe to the display, remove it with a plastic opening tool.
  21. Replacing iPod Nano 7th Generation Display: step 21, image 1 of 1
    • Remove the display from the midframe.
Sam Goldheart
466,931 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
138 Members
17,679 Guides authored
Past 24 Hours: 17
Past 7 Days: 102
Past 30 Days: 518
All Time: 83,846
