Installing iPod Nano 6th Generation Headphone Jack Assembly
  1. Installing iPod Nano 6th Generation Headphone Jack Assembly, Front Panel Assembly: step 1, image 1 of 1
    • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
    • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
  2. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 2, image 1 of 1
    • While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
    • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
    • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
    • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
  3. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 3, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 3, image 2 of 2
    • Lift the front panel assembly from the headphone jack side of the Nano.
    • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
    • The front panel assembly is still attached to the Nano by two cables.
  4. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 4, image 1 of 1
    • Lay the front panel assembly next to the Nano.
    • Remove the following two screws:
    • One 2.3 mm Phillips screw
    • One 2.6 mm shouldered Phillips screw
  5. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 5, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 5, image 2 of 2
    • Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
    • Remove the steel shield from the Nano.
  6. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 6, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 6, image 2 of 2
    • Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
  7. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 7, image 1 of 1
    • Remove the front panel assembly, minding its two cables that may get caught.
    • To reassemble, you can use the double-sided tape found here.
  8. Installing iPod Nano 6th Generation Headphone Jack Assembly, Logic Board Assembly: step 8, image 1 of 1
    • Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
  9. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 9, image 1 of 1
    • Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
  10. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 10, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 10, image 2 of 2
    • Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
    • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
    • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
  11. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 11, image 1 of 1
    • Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
    • Do not excessively pry the logic board upward.
  12. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 12, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 12, image 2 of 2
    • Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
    • Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
  13. Installing iPod Nano 6th Generation Headphone Jack Assembly, Headphone Jack Assembly: step 13, image 1 of 1
    • Remove the following five screws:
    • One 1.7 mm Phillips screw
    • Four 3.9 mm Phillips screws.
  14. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 14, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 14, image 2 of 2
    • Use a pair of tweezers to carefully pull the headphone jack toward the center of the Nano.
    • Avoid pulling on the cable, as it is very thin and delicate. The plastic mounting ear is a safer area to pull on.
  15. Installing iPod Nano 6th Generation Headphone Jack Assembly: step 15, image 1 of 2 Installing iPod Nano 6th Generation Headphone Jack Assembly: step 15, image 2 of 2
    • Very carefully pull the headphone jack assembly ribbon cable toward the dock connector to separate the sleep and volume buttons from the outer case.
    • Remove the headphone jack assembly.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 85
All Time: 92,424
