Introduction
Use this guide to replace the headphone jack assembly. The headphone jack assembly includes the headphone jack and the electronic sleep/volume buttons.
Parts
No parts specified.
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
I strongly recommend using a Small Suction Cup (IF145-019-1) instead of a plastic opening tool.
After half an hour of various heating times, trying to use a plastic opening tool, I overheated the LCD, which caused it to discolour. Now I need to buy a new screen. I wish I'd thought to use a suction cup earlier; it seems so obvious in retrospect.
We have a temperature controlled testing oven at work. I set the oven for 50 degrees C, let it absorb heat for half an hour, then took it out. I had zero luck with either the plastic pry tool or the suction cup, so I carefully pried up the indicated side with the sharp pointed tip of a dental pick until I could get the plastic tool into the crack opening.
Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
How come you did not put back the metal plate that goes between the iPod and the display?
Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
Remove the following five screws:
One 1.7 mm Phillips screw
Four 3.9 mm Phillips screws.
Use a pair of tweezers to carefully pull the headphone jack toward the center of the Nano.
hello all.!!
i replaced the whole assembly (power, volume and headphones). Now my ipod is not getting ON. i followed the whole procedure as mentioned. Can anyone suggest me anymore.
Very carefully pull the headphone jack assembly ribbon cable toward the dock connector to separate the sleep and volume buttons from the outer case.
Remove the headphone jack assembly.
77 other people completed this guide.
13 Comments
My problem was that there was a small plastic bit missing from the on/off-switch. I just glued it back on and now the device works again.
Here is a picture of the plastic bit and the switch where it belongs to:
http://i49.tinypic.com/14t62x4.jpg
And here is a video that helped me to find the issue:
if your problem is that your player is pausing randomly - maybe just try using some WD-40 or similar to clean the contacts will fix that. you can just spray some WD-40 into the headphone-jack without dismantling it.
don't use to much WD-40, and hold your player with the headphone-jack pointing down. otherwise it may happen that the display gets damaged(happend to me - my display now discoloroud because of the liquid / but is functional anyway).
maybe just try using some ~~WD-40 or similar to clean the contacts will fix that. you can just spray some WD-40 into the headphone-jack
..that's because WD-40 is not supposed to be used to clean contact points on electronics. If you already damaged your own device why on earth would you tell someone to ruin their own?
Don't ever use WD-40 to clean any electronic device especially the audio contact points in the headphone jack.
There is plenty of audio contact cleaner available for electronics that is safe for your device to clean and lubricate the jack. I prefer Caig Deoxit for audio contacts particularly as they specialize in a number of contact restoring solutions for everything electronic whether it be mechanical metal structure or plastic surface circuits. www.deoxit.com
I thank you guys so much. Especially the Tips from Dave and Mart Kroon!
This tiny plastic piece is in my opinion a deliberate bad choice for it's function, it can very easily fall out of place and leave a completely functional device useless.
I simply glued it back on with some standard glue which i aplied with the cut-of end of an q-tip. Be sure to use only a tiny amount, since the button can get glued tight and is not movable anymore.
During the disassembly, the plastic piece from my "Decrease-Volume" Button got lost, so i replaced it with a tiny piece of plastic i cut of the q-tip. Be careful not to make it to big. If it is to big and already glued on, you can leave away some or all of the 4 screws holding the buttons in place and just put a piece of plastic between the battery and the cable so the buttons stay in place but can get pressed further in.
A bit of a pedantic point, but the guide calls for a PH00 Phillips screwdriver, and I found that the PH000 fit the screws better.
Also, has this site ever carried the headphone assembly? I have a feeling my power button repair won't last very long and I'll eventually have to replace the entire assembly.
Hi, how are you? I have a question regarding the replacement of the entire headhphone jack flex cable on the ipod nano 6th generation.
Basically I disassembled the old jack and I was ready to put in the new one.
Suddenly I noticed that the "screw holders" (the grey metal/pseudometal things that you use to secure the cable with the screws in the top part and that are glued to the volume and power on buttons)
were not present on the new cable. I tried to unglue them from the old cable, but they were very well glued that I ended up in breaking them.
Is there any way to put inside the new jack without this parts, or to buy new ones (I noticed nobody sell them).
All the videos abd forums I've seen so far don't talk about this aspect and nowhere is shown the reassemble process.
The part I was talking about is this one; as you can see it still has the buttons glued on it and it seems impossible to :
http://s29.postimg.org/r7ywb7g47/2016032...
Please let me know if there is a solution, thank you very much!
@ michele: heating with a hairdryer did the trick for me to recover the small metal parts from the old assembly.
I accidently ran my ipod through the wash cycle after running. I did a long bake out at 60°C. It works fine except that the volume is limited to about half and there is an occasional crackling, fuzzy tone to it with a slightly increased volume for the output. It seems to be associated with the position or pressure applied to the headphone jack.
Can this be fixed by replacing the headphone jack?
Thank you all so much, for the guide and for all the comments. I was able to: disassemble my Nano, diagnose the problem (the tiny black dot from the power button had gotten loose, accidentally tear the headphone jack ribbon cable, order a new part, install the new part, and put the whole thing back together again. (Now I just need some adhesive to get my screen to seal back up.) This is my first repair, and set-backs and all, I am so happy with how it went. It worked out and was a great learning experience. Thank you again!
Does anyone know who can repair my headphone jack? The volume control on the earplug cord is not functioning.
Do I need new adhesive to reassemble?
David Wallin - Reply
