Installing iPod Nano 5th Generation Click Wheel
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing iPod Nano 5th Generation Click Wheel, Click Wheel: step 1, image 1 of 2 Installing iPod Nano 5th Generation Click Wheel, Click Wheel: step 1, image 2 of 2
    • Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
    • Use a low heat setting and do not hold the heat gun in place for too long to avoid melting the plastic bezel.
    • Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
  2. Installing iPod Nano 5th Generation Click Wheel: step 2, image 1 of 3 Installing iPod Nano 5th Generation Click Wheel: step 2, image 2 of 3 Installing iPod Nano 5th Generation Click Wheel: step 2, image 3 of 3
    • Unscrew three screws from the bottom of the iPod:
    • Two 4.4 mm angled Phillips screws
    • One 5.4 mm Phillips screw.
    • These screws may not come out on their own, so be sure not to lose them when removing the retainer.
    • Use a plastic opening tool to pry the metal retainer out from the bottom of the iPod and remove it.
  3. Installing iPod Nano 5th Generation Click Wheel: step 3, image 1 of 2 Installing iPod Nano 5th Generation Click Wheel: step 3, image 2 of 2
    • Insert a metal spudger into the slot at the bottom of the iPod just above the dock connector.
    • Use the metal spudger to pry up the bottom edge of the click wheel.
  4. Installing iPod Nano 5th Generation Click Wheel: step 4, image 1 of 2 Installing iPod Nano 5th Generation Click Wheel: step 4, image 2 of 2
    • Place a guitar pick between the click wheel and the case of the Nano and remove the metal spudger.
    • Pry up the edges of the click wheel with the guitar pick until the click wheel comes free from the case.
    • Do not try to completely remove the click wheel yet, as it is still held in place by a ribbon cable.
  5. Installing iPod Nano 5th Generation Click Wheel: step 5, image 1 of 2 Installing iPod Nano 5th Generation Click Wheel: step 5, image 2 of 2
    • Lift the click wheel out of the way with one hand and use a plastic opening tool to pry the click wheel ribbon cable connector off its socket on the logic board.
    • Remove the click wheel.
Matthew Newsom
39,524 Reputation
67 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 6
All Time: 1,170
