Installing iPod Nano 2nd Generation Display
  1. Installing iPod Nano 2nd Generation Display, Case Assembly: step 1, image 1 of 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. Installing iPod Nano 2nd Generation Display: step 2, image 1 of 1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
  3. Installing iPod Nano 2nd Generation Display: step 3, image 1 of 1
    • When removing the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel.
    • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
  4. Installing iPod Nano 2nd Generation Display: step 4, image 1 of 1
    • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #000 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
  5. Installing iPod Nano 2nd Generation Display: step 5, image 1 of 1
    • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
  6. Installing iPod Nano 2nd Generation Display: step 6, image 1 of 1
    • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
  7. Installing iPod Nano 2nd Generation Display: step 7, image 1 of 1
    • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack. Be careful, this screw is easily stripped.
  8. Installing iPod Nano 2nd Generation Display: step 8, image 1 of 1
    • Lift the bottom bezel bracket out of the iPod.
  9. Installing iPod Nano 2nd Generation Display: step 9, image 1 of 1
    • Remove the two Phillips #00 screws from the top of the iPod.
  10. Installing iPod Nano 2nd Generation Display: step 10, image 1 of 1
    • The highlighted connector attaches the click wheel and headphone jack to the logic board. This cable must be disconnected from the logic board before continuing.
  11. Installing iPod Nano 2nd Generation Display: step 11, image 1 of 1
    • Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
    • Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
  12. Installing iPod Nano 2nd Generation Display: step 12, image 1 of 1
    • Use a spudger to push the logic board through the iPod out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
  13. Installing iPod Nano 2nd Generation Display: step 13, image 1 of 1
    • When removing the logic board, place the tip of the spudger into the hole where you removed the screw and gently push it out. The crevice will keep it in place and decrease the chance of you damaging your board.
  14. Installing iPod Nano 2nd Generation Display: step 14, image 1 of 1
    • Completely remove the display and logic board from the metal casing.
    • When reassembling, ensure that the battery is well seated. If the fit is too tight, the edge of the display will score the inside of the screen window.
  15. Installing iPod Nano 2nd Generation Display, Display: step 15, image 1 of 1
    • Use a spudger to gently pry the battery up from the back of the display. Be careful not to put too much pressure on the display with your spudger.
  16. Installing iPod Nano 2nd Generation Display: step 16, image 1 of 1
    • Use a metal spudger to carefully pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display. By working from the inside of the display, you won't be able to accidentially pry up the clear plastic shielding.
  17. Installing iPod Nano 2nd Generation Display: step 17, image 1 of 1
    • Peel up the orange tape covering the display ribbon cable.
  18. Installing iPod Nano 2nd Generation Display: step 18, image 1 of 1
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
  19. Installing iPod Nano 2nd Generation Display: step 19, image 1 of 1
    • Slide the display ribbon out of its connector and lift the display off of the logic board.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 235
All Time: 92,683
