Installing iPod Nano 2nd Generation Case Assembly
  1. Installing iPod Nano 2nd Generation Case Assembly, Case Assembly: step 1, image 1 of 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. Installing iPod Nano 2nd Generation Case Assembly: step 2, image 1 of 1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
  3. Installing iPod Nano 2nd Generation Case Assembly: step 3, image 1 of 1
    • When removing the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel.
    • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
  4. Installing iPod Nano 2nd Generation Case Assembly: step 4, image 1 of 1
    • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #00 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
  5. Installing iPod Nano 2nd Generation Case Assembly: step 5, image 1 of 1
    • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
  6. Installing iPod Nano 2nd Generation Case Assembly: step 6, image 1 of 1
    • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
  7. Installing iPod Nano 2nd Generation Case Assembly: step 7, image 1 of 1
    • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack. Be careful, this screw is easily stripped.
  8. Installing iPod Nano 2nd Generation Case Assembly: step 8, image 1 of 1
    • Lift the bottom bezel bracket out of the iPod.
  9. Installing iPod Nano 2nd Generation Case Assembly: step 9, image 1 of 1
    • Remove the two Phillips #00 screws from the top of the iPod.
  10. Installing iPod Nano 2nd Generation Case Assembly: step 10, image 1 of 1
    • The highlighted connector attaches the click wheel and headphone jack to the logic board. This cable must be disconnected from the logic board before continuing.
  11. Installing iPod Nano 2nd Generation Case Assembly: step 11, image 1 of 1
    • Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
    • Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
  12. Installing iPod Nano 2nd Generation Case Assembly: step 12, image 1 of 1
    • Use a spudger to push the logic board through the iPod out of the casing. The click wheel and headphone jack should remain in the iPod.
    • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
  13. Installing iPod Nano 2nd Generation Case Assembly: step 13, image 1 of 1
    • Completely remove the display and logic board from the metal casing.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 88
All Time: 57,357
