Shop the Holiday Gift Guide
PSP 1000 Front Casing Replacement
Views: 55K
View statistics:
Past 24 Hours:
24
Past 7 Days:
138
Past 30 Days:
691
All Time:
55,129
Comments: 13
10 comments on steps, 3 guide comments.
Go to guide comments
Completed: 38
38 people have marked this guide "completed." Will you be next?
Favorites: 28
28 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the PSP's housing/frame.
Tools
    1. PSP 1000 Front Casing Replacement, Battery: step 1, image 1 of 1
      • Turn the PSP over so its back is facing you.
      Ask FixBot
    2. PSP 1000 Front Casing Replacement: step 2, image 1 of 2 PSP 1000 Front Casing Replacement: step 2, image 2 of 2
      • Locate the battery casing button on the rear-left side of the PSP.
      • Press down the button and remove the battery cover.
      Ask FixBot
    3. PSP 1000 Front Casing Replacement: step 3, image 1 of 2 PSP 1000 Front Casing Replacement: step 3, image 2 of 2
      • Using your finger, remove the battery upwards from the system as shown.
      Ask FixBot
    1. PSP 1000 Front Casing Replacement, Front Casing: step 4, image 1 of 1
      • Remove the four screws shown with a Phillips #00 screwdriver.
      • You will have to peel back the warranty sticker to access the lower screws.
      Ask FixBot
    2. PSP 1000 Front Casing Replacement: step 5, image 1 of 2 PSP 1000 Front Casing Replacement: step 5, image 2 of 2
      • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
      • Remove the two screws from the back righthand side within the holes.
      Ask FixBot
    3. PSP 1000 Front Casing Replacement: step 6, image 1 of 2 PSP 1000 Front Casing Replacement: step 6, image 2 of 2
      • Gently separate the outer plastic casing from the rest of the system as shown.
      Ask FixBot
38 other people completed this guide.
Author
with
Henry Lee
926 Reputation
4 Guides authored
Cal Poly, Team 5-6, Forte Winter 2010 Member of Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Members
72 Guides authored
3 Guide Comments
Thank you! Awesome help!
Jay Vee - Reply Share
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Reply Share
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Reply Share
Past 24 Hours: 24
Past 7 Days: 138
Past 30 Days: 691
All Time: 55,129
