Hover-1 Superstar Battery Replacement
    1. Hover-1 Superstar Battery Replacement, Bottom Case: step 1, image 1 of 3 Hover-1 Superstar Battery Replacement, Bottom Case: step 1, image 2 of 3 Hover-1 Superstar Battery Replacement, Bottom Case: step 1, image 3 of 3
      • Flip your Hover-1 Superstar device upside down.
      • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
      • Remove the bottom case. Be careful of the connector holding the case and the device together.
      Ask FixBot
    2. Hover-1 Superstar Battery Replacement: step 2, image 1 of 1
      • Locate the cable connected to the front lights.
      • Pull apart the wires until the black clip separates.
      Ask FixBot
    1. Hover-1 Superstar Battery Replacement, Battery: step 3, image 1 of 2 Hover-1 Superstar Battery Replacement, Battery: step 3, image 2 of 2
      • Locate the four 14mm screws securing the battery bracket.
      • Remove the screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Hover-1 Superstar Battery Replacement: step 4, image 1 of 1
      • Pull and disconnect the cable connector that is connected to the battery.
      Ask FixBot
    3. Hover-1 Superstar Battery Replacement: step 5, image 1 of 1
      • Pull on the battery until it separates from the hover board. You may need to use some force.
      • Be sure the battery is disconnected before performing this step to avoid electrocution.
      • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
      • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
      Ask FixBot
1 Guide Comment
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - Reply Share
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 32
All Time: 2,439
