Toshiba Satellite C55-A5300 CD Drive Replacement
    1. Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: step 1, image 3 of 3
      • With the Laptop off, turn it over.
      • The battery is located next to the screen hinges.
      • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
      Ask FixBot
    2. Toshiba Satellite C55-A5300 CD Drive Replacement: step 2, image 1 of 3 Toshiba Satellite C55-A5300 CD Drive Replacement: step 2, image 2 of 3 Toshiba Satellite C55-A5300 CD Drive Replacement: step 2, image 3 of 3
      • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
      • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
      Ask FixBot
    1. Toshiba Satellite C55-A5300 CD Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Unscrew the screw on the back panel of the laptop covering the hard drive.
      Ask FixBot
    2. Toshiba Satellite C55-A5300 CD Drive Replacement: step 4, image 1 of 1
      • Use the plastic opening tools to remove the panel.
      Ask FixBot
    3. Toshiba Satellite C55-A5300 CD Drive Replacement: step 5, image 1 of 1
      • Remove the screw next to the hard drive using the PH1 screwdriver.
      Ask FixBot
    4. Toshiba Satellite C55-A5300 CD Drive Replacement: step 6, image 1 of 1
      • Pull the silver tab connected to the hard drive up to take it out.
      Ask FixBot
    1. Toshiba Satellite C55-A5300 CD Drive Replacement, CD Drive: step 7, image 1 of 1
      • Remove the screw to the top right of the hard drive using the PH1 screwdriver.
      Ask FixBot
    2. Toshiba Satellite C55-A5300 CD Drive Replacement: step 8, image 1 of 1
      • Use the plastic opening tool to wedge between the CD Drive and the laptop casing and gently pull it out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 17
Past 30 Days: 45
All Time: 637
