Dell Inspiron 15-7567 Touchpad Replacement
    1. Dell Inspiron 15-7567 Touchpad  Replacement, Battery: step 1, image 1 of 1
      • Turn off laptop before beginning.
      • Place the laptop upside down on a flat, stable surface.
      Ask FixBot
    2. Dell Inspiron 15-7567 Touchpad  Replacement: step 2, image 1 of 2 Dell Inspiron 15-7567 Touchpad  Replacement: step 2, image 2 of 2
      • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
      Ask FixBot
    3. Dell Inspiron 15-7567 Touchpad  Replacement: step 3, image 1 of 1
      • Remove the panel from the sides and pull it out at an angle towards you.
      Ask FixBot
    4. Dell Inspiron 15-7567 Touchpad  Replacement: step 4, image 1 of 2 Dell Inspiron 15-7567 Touchpad  Replacement: step 4, image 2 of 2
      • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
      Ask FixBot
    5. Dell Inspiron 15-7567 Touchpad  Replacement: step 5, image 1 of 2 Dell Inspiron 15-7567 Touchpad  Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
      • Pinch the clips on the left and right side while pulling on the cord at the same time.
      Ask FixBot
    6. Dell Inspiron 15-7567 Touchpad  Replacement: step 6, image 1 of 1
      • Pull the battery towards you.
      • Make sure to pull at an upward angle.
      Ask FixBot
    1. Dell Inspiron 15-7567 Touchpad  Replacement, Touchpad: step 7, image 1 of 1
      Buy
      • Remove the clip holding the power cord on the Touch Pad by using tweezers, your fingers, or iFixit removing tools to gently pull up on the clip.
      • This should release the power cord as shown.
      Ask FixBot
    2. Dell Inspiron 15-7567 Touchpad  Replacement: step 8, image 1 of 1
      • Remove the four 3mm screws using a Phillips #1 screwdriver in the locations shown.
      Ask FixBot
    3. Dell Inspiron 15-7567 Touchpad  Replacement: step 9, image 1 of 1
      • Remove Touch Pad by pulling towards you gently at a slight upward angle.
      • The Touch Pad is now removed and ready to be replaced.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 47
All Time: 2,547
