Sony Cyber-Shot DSC-H1 Lens Replacement
    1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: step 1, image 1 of 1
      • Power down the camera and remove the batteries.
      Ask FixBot
    2. Sony Cyber-Shot DSC-H1 Lens Replacement: step 2, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 2, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 2, image 3 of 3
      • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
      • There are six 5.22mm long, 3.00mm head diameter screws total.
      • The left side is not shown but there should be 1 screw on that side.
      Ask FixBot
    3. Sony Cyber-Shot DSC-H1 Lens Replacement: step 3, image 1 of 2 Sony Cyber-Shot DSC-H1 Lens Replacement: step 3, image 2 of 2
      • Remove the back casing.
      • The casing itself is sturdy so don't be afraid to remove it forcefully.
      Ask FixBot
    1. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: step 4, image 1 of 1
      • Take a hold of the right side of the LCD screen and lift it towards the left.
      • The screen is held firm and will require a bit of force to ease it from its housing.
      Ask FixBot
    2. Sony Cyber-Shot DSC-H1 Lens Replacement: step 5, image 1 of 1
      • Unplug the large conductive tape attached to the screen.
      • Remove the LCD from the device.
      Ask FixBot
    1. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: step 6, image 1 of 2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: step 6, image 2 of 2
      • Unscrew and remove the gray backing behind the LCD screen.
      Ask FixBot
    2. Sony Cyber-Shot DSC-H1 Lens Replacement: step 7, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 7, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
      • Disconnect the white conductive tape.
      • Remove the blue panel.
      • Use tweezers to remove the three conductive tape strips on the right side.
      Ask FixBot
    3. Sony Cyber-Shot DSC-H1 Lens Replacement: step 8, image 1 of 2 Sony Cyber-Shot DSC-H1 Lens Replacement: step 8, image 2 of 2
      • Use tweezers to remove the orange conductive tape located below the shutter.
      • Unplug the three ZIF connectors from the motherboard.
      Ask FixBot
    4. Sony Cyber-Shot DSC-H1 Lens Replacement: step 9, image 1 of 1
      • Flip up the blue overlapping board at the top.
      • Use tweezers to disconnect the remaining connectors.
      Ask FixBot
    5. Sony Cyber-Shot DSC-H1 Lens Replacement: step 10, image 1 of 1
      • Remove the motherboard and battery pack unit.
      Ask FixBot
    6. Sony Cyber-Shot DSC-H1 Lens Replacement: step 11, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 11, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 11, image 3 of 3
      • Use a screwdriver to remove 5 screws on plastic panel.
      • Remove the single screw on the silver panel in the center.
      Ask FixBot
    7. Sony Cyber-Shot DSC-H1 Lens Replacement: step 12, image 1 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 12, image 2 of 3 Sony Cyber-Shot DSC-H1 Lens Replacement: step 12, image 3 of 3
      • Use tweezers to remove the blue control panel.
      • Remove the lens from the camera.
      Ask FixBot
4 other people completed this guide.
Charlie Pugeda
547 Reputation
3 Guides authored
Baylor, Team S5-G4, Williams Spring 2018 Member of Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Members
55 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 58
All Time: 2,606
