HP Pavilion 15-ba003ds Screen Replacement
    1. HP Pavilion 15-ba003ds Screen Replacement, Screen: step 1, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: step 1, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: step 1, image 3 of 3
      • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
      • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
      Ask FixBot
    2. HP Pavilion 15-ba003ds Screen Replacement: step 2, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 2, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 2, image 3 of 3
      • Continue sliding the metal spudger to the bottom of the screen.
      • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
      Ask FixBot
    3. HP Pavilion 15-ba003ds Screen Replacement: step 3, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 3, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 3, image 3 of 3
      • Flip the laptop so the bottom is facing upwards.
      • Using the metal spudger, separate the plastic panel off the screen.
      Ask FixBot
    4. HP Pavilion 15-ba003ds Screen Replacement: step 4, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 4, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 4, image 3 of 3
      • Once the panel is separated from the screen, gently pull it off and set it aside.
      • Remove two 6mm Phillips #00 screws from the bottom of the screen.
      Ask FixBot
    5. HP Pavilion 15-ba003ds Screen Replacement: step 5, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 5, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 5, image 3 of 3
      • Remove two 6mm Phillips #00 screws from the top of the screen.
      Ask FixBot
    6. HP Pavilion 15-ba003ds Screen Replacement: step 6, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 6, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 6, image 3 of 3
      • Flip the screen down.
      • Remove the tape from over the connector.
      • Pull out the connector using your fingers.
      Ask FixBot
    7. HP Pavilion 15-ba003ds Screen Replacement: step 7, image 1 of 1
      • Lift the screen away from the laptop.
      Ask FixBot
Joseph Chia
355 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 625
