Shop the Holiday Gift Guide
LG VX4500 Keypad Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
34
All Time:
1,387
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the keypad.
Tools
    1. LG VX4500 Keypad Replacement, Battery: step 1, image 1 of 1
      • Turn the closed phone so that the back panel is facing you.
      • Press down and forward firmly on the gray tab in the middle of the phone.
      Ask FixBot
    2. LG VX4500 Keypad Replacement: step 2, image 1 of 2 LG VX4500 Keypad Replacement: step 2, image 2 of 2
      • Now just lift up on the battery and remove it from the phone.
      Ask FixBot
    1. LG VX4500 Keypad Replacement, Rear Cover: step 3, image 1 of 1
      • Remove the rubber grommet using a spudger.
      Ask FixBot
    2. LG VX4500 Keypad Replacement: step 4, image 1 of 1
      • Be sure not to lose the screws. They are small!
      • Remove the five screws using a Phillips #00 Screwdriver.
      Ask FixBot
    3. LG VX4500 Keypad Replacement: step 5, image 1 of 3 LG VX4500 Keypad Replacement: step 5, image 2 of 3 LG VX4500 Keypad Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • When removing back cover, be careful not to break the speaker wires.
      • Using an Opening Tool, carefully pry off the back cover.
      • Using tweezers, gently pull the speaker wires out.
      Ask FixBot
    4. LG VX4500 Keypad Replacement: step 6, image 1 of 1
      • Separate the two halves.
      Ask FixBot
    1. LG VX4500 Keypad Replacement, Keypad: step 7, image 1 of 3 LG VX4500 Keypad Replacement, Keypad: step 7, image 2 of 3 LG VX4500 Keypad Replacement, Keypad: step 7, image 3 of 3
      • Carefully pry and lift up on the logic board using an iPod Opening Tool.
      Ask FixBot
    2. LG VX4500 Keypad Replacement: step 8, image 1 of 1
      • Carefully flip the logic board up and out of the way.
      Ask FixBot
    3. LG VX4500 Keypad Replacement: step 9, image 1 of 3 LG VX4500 Keypad Replacement: step 9, image 2 of 3 LG VX4500 Keypad Replacement: step 9, image 3 of 3
      • Use an iPod Opening Tool to lift up on the keypad and pull it out.
      Ask FixBot
Author
with
David Foster
1 Reputation
8 Guides authored
Cal Poly, Team 25-88, Amido Spring 2010 Member of Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 1,387
