Introduction
Go to step 1 ↓Replace the aluminum bottom case in a MacBook Pro 13" Unibody.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
53 other people completed this guide.
1 Guide Comment
2 tornillos se da&aron, los q estan al lado de las lenguetas de montaje -lado de la bateria- pues la bateria se inflo y presiona la carcasa
q haces p resolver ??
