Acer Aspire E3-111-C0WA Touchpad Replacement
  1. Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: step 1, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement, Battery: step 1, image 2 of 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Touchpad Replacement: step 2, image 1 of 3 Acer Aspire E3-111-C0WA Touchpad Replacement: step 2, image 2 of 3 Acer Aspire E3-111-C0WA Touchpad Replacement: step 2, image 3 of 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Touchpad Replacement: step 3, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement: step 3, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Touchpad Replacement: step 4, image 1 of 3 Acer Aspire E3-111-C0WA Touchpad Replacement: step 4, image 2 of 3 Acer Aspire E3-111-C0WA Touchpad Replacement: step 4, image 3 of 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Touchpad Replacement: step 5, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement: step 5, image 2 of 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Touchpad Replacement: step 6, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement: step 6, image 2 of 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: step 7, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement, Touchpad: step 7, image 2 of 2
    • Lift up on the black tab to release the ribbon cable from the touchpad.
    • Lightly pull on the blue tab to remove the cable from the connector.
  8. Acer Aspire E3-111-C0WA Touchpad Replacement: step 8, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement: step 8, image 2 of 2
    • Peel up the silver tape adhering the touchpad cable to the case, revealing two screws underneath.
  9. Acer Aspire E3-111-C0WA Touchpad Replacement: step 9, image 1 of 2 Acer Aspire E3-111-C0WA Touchpad Replacement: step 9, image 2 of 2
    • Unscrew the three 6.2mm Phillips #1 screws holding the touchpad to the case.
  10. Acer Aspire E3-111-C0WA Touchpad Replacement: step 10, image 1 of 3 Acer Aspire E3-111-C0WA Touchpad Replacement: step 10, image 2 of 3 Acer Aspire E3-111-C0WA Touchpad Replacement: step 10, image 3 of 3
    • Lift the touchpad assembly out of the case by its corners.
    • Slide the touchpad out of the chassis from under the speaker cable, taking care not to damage the cable.
    • Check to make sure the small strip of conductive tape connecting the copper pad on the PCB to the metal assembly is properly adhered.
Jonathan Chandler
503 Reputation
4 Guides authored
2 Guide Comments
Well made instruction, presumably works on all E3-111 devices; it did on my E3-111-C45G.
The spare parts number (Europe) is Acer No. TAA4329129, dubbed “Original Acer Touchpad / Touchboard silver Aspire E3-11 series”. Should cost around 22-25€.
ce re - Reply Share
In der Anleitung sollte zwingend erwähnt werden das jedes Silberne Tape (Tape conductive adhesive) wieder blasenfrei anzukleben ist. Wenn es eingerissen oder abgerissen ist dann ist es zu ersetzen weil es zur Erdung dient gerade im Bereich des Touchpads! Alternativ kann dann auch ein Kupfer Tape genutzt werden aber auch der Kleber auf dem Tape sollte elektrisch Leitfähig sein.
Black_B33tl3 - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 1,432
