This teardown is not a repair guide. To repair your iPhone Air, use our service manual.
    1. iPhone Air Chip ID, Main Board - Outer Side: step 1, image 1 of 2 iPhone Air Chip ID, Main Board - Outer Side: step 1, image 2 of 2
      • Kioxia K8A7RJ5126 ? 256 GB NAND flash memory
      • NXP Semiconductors CBTL1701B0 USB Type-C port controller
      • Apple APL1064/338S01279 power management
      • Texas Instruments CP3200C1H3 battery charger
      • Apple/Cirrus Logic 338S00967 audio codec
      • Apple/Cirrus Logic 338S01148 audio amplifier
      • Broadcom BCM59367A1IUBG wireless charging controller
      Ask FixBot
    2. iPhone Air Chip ID: step 2, image 1 of 1
      • Qorvo QM81026H envelope tracker
      Ask FixBot
    3. iPhone Air Chip ID, Main Board - Outer Side - Connectivity: step 3, image 1 of 1
      • Apple APL1114/337S01030 5G modem
      • Apple APL1088/338S01150 RF transceiver
      • Skyworks SKY58452-14 front-end module
      • Broadcom AFEM-8254 front-end module
      • Broadcom AFEM-8255 front-end module
      • Broadcom AFEM-8277 front-end module
      • Skyworks SKY53921-16 front-end module
      Ask FixBot
    4. iPhone Air Chip ID, Main Board - Outer Side - Sensors: step 4, image 1 of 1
      • Bosch Sensortec accelerometer & gyroscope
      Ask FixBot
    5. iPhone Air Chip ID, Main Board - Inner Side: step 5, image 1 of 2 iPhone Air Chip ID, Main Board - Inner Side: step 5, image 2 of 2
      • Apple APL1V12/339S01839 hexa-core applications processor w/ GPU & Neural Engine layered under a Samsung K3KLMLM0FM-HGGV 12 GB LPDDR5X SDRAM
      • Texas Instruments TPS65658A0 display power supply
      • Analog Devices MAX11390A analog to digital converter
      • Analog Devices MAX20348P DC-DC converter
      • Possibly Texas Instruments CP5100A0 camera flash controller
      Ask FixBot
    6. iPhone Air Chip ID, Main Board - Inner Side - Connectivity: step 6, image 1 of 1
      • USI ? 339M00400 WiFi 7, Bluetooth 6, and Thread Module (contains Apple N1)
      Ask FixBot
    7. iPhone Air Chip ID, NFC Board: step 7, image 1 of 2 iPhone Air Chip ID, NFC Board: step 7, image 2 of 2
      • STMicroelectronics STPMIA3A power management
      • Likely STMicroelectronics STB605A11 power management
      • Apple 338S00616 DC-DC converter
      Ask FixBot
    8. iPhone Air Chip ID, NFC Board - Connectivity: step 8, image 1 of 1
      • NXP Semiconductors SN300 NFC controller w/ eSIM & secure element
      • Possibly NXP Semiconductors NFC controller
      Ask FixBot
    9. iPhone Air Chip ID, UWB Board - Connectivity: step 9, image 1 of 2 iPhone Air Chip ID, UWB Board - Connectivity: step 9, image 2 of 2
      • USI ? 339M00384 UWB Module (contains Apple U2)
      Ask FixBot
3 Guide Comments
What about the thing above the A19? You didn't mentioned it.
boris_dg - Reply Share
Probably because it is not that interesting. It's a shield which covers the main power supply.
Jason Morganson - Reply Share
Do you have iphone17 pro tear down chip informatopn?
Pin-Jun Lin - Reply Share
Past 24 Hours: 32
Past 7 Days: 223
Past 30 Days: 1,133
All Time: 24,036
