Samsung SCV-VLUUST50 Flash Bulb Replacement
  1. Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: step 1, image 1 of 3 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: step 1, image 2 of 3 Samsung SCV-VLUUST50 Flash Bulb Replacement, Cover: step 1, image 3 of 3
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Bulb Replacement: step 2, image 1 of 3 Samsung SCV-VLUUST50 Flash Bulb Replacement: step 2, image 2 of 3 Samsung SCV-VLUUST50 Flash Bulb Replacement: step 2, image 3 of 3
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Bulb Replacement: step 3, image 1 of 1
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Bulb Replacement: step 4, image 1 of 2 Samsung SCV-VLUUST50 Flash Bulb Replacement: step 4, image 2 of 2
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: step 5, image 1 of 2 Samsung SCV-VLUUST50 Flash Bulb Replacement, Flash Bulb: step 5, image 2 of 2
    • Remove the screw securing the shutter button to the camera frame.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Bulb Replacement: step 6, image 1 of 2 Samsung SCV-VLUUST50 Flash Bulb Replacement: step 6, image 2 of 2
    • Remove the screws from the circuitry with a Phillips #000 driver.
    • Remove the screw connecting the flash housing to the camera frame with the same driver.
  7. Samsung SCV-VLUUST50 Flash Bulb Replacement: step 7, image 1 of 2 Samsung SCV-VLUUST50 Flash Bulb Replacement: step 7, image 2 of 2
    • Pull the flash housing away from the camera frame.
    • Cut the wires connecting the flash module to the circuitry.
    • Connect the new flash module to the circuitry with a soldering iron and electrical solder.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 24
All Time: 357
