HP eStation Zeen Speaker Replacement
  1. HP eStation Zeen Speaker Replacement, Speaker: step 1, image 1 of 3 HP eStation Zeen Speaker Replacement, Speaker: step 1, image 2 of 3 HP eStation Zeen Speaker Replacement, Speaker: step 1, image 3 of 3
    • Remove the rubber screw caps using a metal spudger.
    • Remove the two 6mm screw using a Phillips #0 screwdriver.
  2. HP eStation Zeen Speaker Replacement: step 2, image 1 of 3 HP eStation Zeen Speaker Replacement: step 2, image 2 of 3 HP eStation Zeen Speaker Replacement: step 2, image 3 of 3
    • Unclip each side by inserting the plastic opening tool and slide it along the edges.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Speaker Replacement: step 3, image 1 of 1
    • Disconnect battery clip.
    • The clip is very fragile.
  4. HP eStation Zeen Speaker Replacement: step 4, image 1 of 1
    • Disconnect the speaker wires from the terminal using a plastic opening tool.
    • Be careful the plastic connector is fragile
  5. HP eStation Zeen Speaker Replacement: step 5, image 1 of 1
    • Remove the two 6mm screws using a Phillips #0 screwdriver.
Jack Clark
120 Reputation
1 Guide authored
USF Tampa, Team 16-4, Eyestone Fall 2016 Member of USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 270
