Dell Inspiron B130 Hard Drive Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
76
All Time:
1,107
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
In this guide you will learn how to replace the hard drive on your Dell B130. The hard drive is where the computer stores any information and there may be problems with it if: the computer is slow, is unable to boot, or has errors when trying to read or delete data.
Tools
    1. Dell Inspiron B130 Hard Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron B130 Hard Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron B130 Hard Drive Replacement, Battery: step 1, image 3 of 3
      • First, make sure your computer is turned off.
      • Remove the battery by flipping the two switches under the battery and pulling it out
      Ask FixBot
    2. Dell Inspiron B130 Hard Drive Replacement: step 2, image 1 of 3 Dell Inspiron B130 Hard Drive Replacement: step 2, image 2 of 3 Dell Inspiron B130 Hard Drive Replacement: step 2, image 3 of 3
      • Push the tab from the battery, downwards to unlock the battery.
      • The tab should be in the position next to the unlocked indicator.
      Ask FixBot
    3. Dell Inspiron B130 Hard Drive Replacement: step 3, image 1 of 3 Dell Inspiron B130 Hard Drive Replacement: step 3, image 2 of 3 Dell Inspiron B130 Hard Drive Replacement: step 3, image 3 of 3
      • Now, push the other tab (the one right under the battery) from right to left.
      • Now the battery will be loose; lift the battery up and out of the computer.
      Ask FixBot
    1. Dell Inspiron B130 Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
      • This particular computer is missing its hard drive.
      • Remove the two screws.
      • Remove the plastic cover by lifting from the groove as indicated.
      • Remove the hard drive from the computer by lifting up and out.
      Ask FixBot
Patrick McNeil
955 Reputation
8 Guides authored
UMass Dartmouth, Team 1-8, Catania Fall 2016 Member of UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 76
All Time: 1,107
