HMDX Chill Disassembly
    1. HMDX Chill Disassembly, Remove Rubber Base: step 1, image 1 of 3 HMDX Chill Disassembly, Remove Rubber Base: step 1, image 2 of 3 HMDX Chill Disassembly, Remove Rubber Base: step 1, image 3 of 3
      • Insert a metal spudger under the rubber base.
      • Pry the rubber base off.
      Ask FixBot
    2. HMDX Chill Disassembly: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
      Ask FixBot
    3. HMDX Chill Disassembly: step 3, image 1 of 2 HMDX Chill Disassembly: step 3, image 2 of 2
      • Grip the base of the HMDX Chill.
      • Pull the base upwards.
      Ask FixBot
Jourdan Holubasch
759 Reputation
7 Guides authored
EWU-Giguere-S16S1G1 Member of EWU-Giguere-S16S1G1
Community
4 Members
84 Guides authored
1 Guide Comment
I have jam zero chill. One year old. Very very little use. Maybe 3 to 4 hours total.
Plug in to charge red light comes on solid and goes out in couple of hours. Then light flashes red and zero chill will not connect.
Thank you
Lorne Janes - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 52
All Time: 1,916
