iPhone 6 Plus Speaker Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Speaker Replacement, Speaker: step 1, image 1 of 2 iPhone 6 Plus Speaker Replacement, Speaker: step 1, image 2 of 2
    • Grasp the antenna connector with a pair of tweezers and carefully begin de-routing it from its channel on the speaker.
  2. iPhone 6 Plus Speaker Replacement: step 2, image 1 of 1
    • To fully de-route the antenna connector, you may need to gently pull back the metal clip securing it to the speaker assembly.
  3. iPhone 6 Plus Speaker Replacement: step 3, image 1 of 1
    • Remove the following screws securing the speaker to the rear case:
    • One 2.3 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  4. iPhone 6 Plus Speaker Replacement: step 4, image 1 of 1
    • Lift and remove the speaker out of the iPhone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 227
