iPhone 6 Plus Logic Board Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 6 Plus Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 1
      • Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
      Ask FixBot
    2. iPhone 6 Plus Logic Board Assembly Replacement: step 2, image 1 of 1
      • Remove the single 1.3 mm Phillips #00 screw recessed against the top of the rear case.
      Ask FixBot
    3. iPhone 6 Plus Logic Board Assembly Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to firmly grasp the plastic clip and remove it from the iPhone.
      Ask FixBot
    4. iPhone 6 Plus Logic Board Assembly Replacement: step 4, image 1 of 1
      • Remove the single 1.6 mm Phillips #00 screw securing the antenna clip to the rear case.
      Ask FixBot
    5. iPhone 6 Plus Logic Board Assembly Replacement: step 5, image 1 of 1
      • Carefully grasp the antenna clip with a pair of tweezers and remove it from the iPhone.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 560
