iPhone 6 Plus Lightning Connector Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 1, image 1 of 1
    • Remove the two 3.3 mm Phillips #00 screws securing the metal bracket to the Lightning connector assembly.
  2. iPhone 6 Plus Lightning Connector Assembly Replacement: step 2, image 1 of 1
    • Use a pair of tweezers to lift and remove the metal bracket out of the iPhone.
  3. iPhone 6 Plus Lightning Connector Assembly Replacement: step 3, image 1 of 1
    • Use the flat edge of a spudger to pry the antenna connector cable up off its socket on the Lightning connector assembly.
  4. iPhone 6 Plus Lightning Connector Assembly Replacement: step 4, image 1 of 1
    • Lift and remove the antenna connector out of the iPhone.
  5. iPhone 6 Plus Lightning Connector Assembly Replacement: step 5, image 1 of 1
    • Remove the following Phillips #00 screws securing the Lightning connector assembly to the rear case:
    • Two 3.2 mm screws
    • One 3.8 mm screw
    • Two 1.7 mm screws
    • Two 1.5 mm screws
    • Two 1.4 mm screws
  6. iPhone 6 Plus Lightning Connector Assembly Replacement: step 6, image 1 of 1
    • Use a pair of tweezers to grasp the plastic clip that is situated to the right of the headphone jack and remove it from the iPhone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 587
