Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Prereq only for rear case.
  1. Remove the two 3.3 mm Phillips #00 screws securing the metal bracket to the Lightning connector assembly.
    • Remove the two 3.3 mm Phillips #00 screws securing the metal bracket to the Lightning connector assembly.
  2. Use a pair of tweezers to lift and remove the metal bracket out of the iPhone.
    • Use a pair of tweezers to lift and remove the metal bracket out of the iPhone.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Use the flat edge of a spudger to pry the antenna connector cable up off its socket on the Lightning connector assembly.
    • Use the flat edge of a spudger to pry the antenna connector cable up off its socket on the Lightning connector assembly.
  5. Lift and remove the antenna connector out of the iPhone.
    • Lift and remove the antenna connector out of the iPhone.
  6. Remove the following Phillips #00 screws securing the Lightning connector assembly to the rear case:
    • Remove the following Phillips #00 screws securing the Lightning connector assembly to the rear case:
    • Two 3.2 mm screws
    • One 3.8 mm screw
    • Two 1.7 mm screws
    • Two 1.5 mm screws
    • Two 1.4 mm screws
  7. Use a pair of tweezers to grasp the plastic clip that is situated to the right of the headphone jack and remove it from the iPhone.
    • Use a pair of tweezers to grasp the plastic clip that is situated to the right of the headphone jack and remove it from the iPhone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 503
