iPhone 6 Plus Lightning Connector Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 6 Plus Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 1, image 1 of 1
      • Remove the two 3.3 mm Phillips #00 screws securing the metal bracket to the Lightning connector assembly.
      Ask FixBot
    2. iPhone 6 Plus Lightning Connector Assembly Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift and remove the metal bracket out of the iPhone.
      Ask FixBot
    3. iPhone 6 Plus Lightning Connector Assembly Replacement: step 3, image 1 of 1
      • Use the flat edge of a spudger to pry the antenna connector cable up off its socket on the Lightning connector assembly.
      Ask FixBot
    4. iPhone 6 Plus Lightning Connector Assembly Replacement: step 4, image 1 of 1
      • Lift and remove the antenna connector out of the iPhone.
      Ask FixBot
    5. iPhone 6 Plus Lightning Connector Assembly Replacement: step 5, image 1 of 1
      • Remove the following Phillips #00 screws securing the Lightning connector assembly to the rear case:
      • Two 3.2 mm screws
      • One 3.8 mm screw
      • Two 1.7 mm screws
      • Two 1.5 mm screws
      • Two 1.4 mm screws
      Ask FixBot
    6. iPhone 6 Plus Lightning Connector Assembly Replacement: step 6, image 1 of 1
      • Use a pair of tweezers to grasp the plastic clip that is situated to the right of the headphone jack and remove it from the iPhone.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 2,100
