iPhone 6 Plus Anti-Clamp Opening Procedure
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Anti-Clamp Opening Procedure, Anti-Clamp Opening Procedure: step 1, image 1 of 3 iPhone 6 Plus Anti-Clamp Opening Procedure, Anti-Clamp Opening Procedure: step 1, image 2 of 3 iPhone 6 Plus Anti-Clamp Opening Procedure, Anti-Clamp Opening Procedure: step 1, image 3 of 3
    Tool used on this step:
    iSclack
    $24.99
    Buy
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
    • Close the handle on the iSclack, opening the suction cup jaws.
    • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, near the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
  2. iPhone 6 Plus Anti-Clamp Opening Procedure: step 2, image 1 of 2 iPhone 6 Plus Anti-Clamp Opening Procedure: step 2, image 2 of 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 7.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 623
