iPhone 6 Plus Antenna Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 Plus Antenna Assembly Replacement, Antenna Assembly: step 1, image 1 of 1
    • Remove the following screws securing the antenna bracket to the rear case:
    • One 1.5 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  2. iPhone 6 Plus Antenna Assembly Replacement: step 2, image 1 of 1
    • Grasp the antenna bracket with a pair of tweezers and lift it off the iPhone.
  3. iPhone 6 Plus Antenna Assembly Replacement: step 3, image 1 of 1
    • Carefully pry the antenna connector up off the logic board with a plastic opening tool.
  4. iPhone 6 Plus Antenna Assembly Replacement: step 4, image 1 of 2 iPhone 6 Plus Antenna Assembly Replacement: step 4, image 2 of 2
    • Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
  5. iPhone 6 Plus Antenna Assembly Replacement: step 5, image 1 of 2 iPhone 6 Plus Antenna Assembly Replacement: step 5, image 2 of 2
    • The two connectors may be coupled by a single adhesive tab. If this is the case, then they may detach as a pair.
    • Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
  6. iPhone 6 Plus Antenna Assembly Replacement: step 6, image 1 of 1
    • Remove the following screws securing the top cellular antenna to the rear case:
    • Two 1.6 mm Phillips #00 screws
  7. iPhone 6 Plus Antenna Assembly Replacement: step 7, image 1 of 2 iPhone 6 Plus Antenna Assembly Replacement: step 7, image 2 of 2
    • Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone.
    • During reassembly, make sure to place the small washer in the top left corner of the antenna assembly.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,059
