iPhone 6 iSclack Opening Procedure
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 6 iSclack Opening Procedure, iSclack Opening Procedure: step 1, image 1 of 1
    • The next three steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down three steps for an alternate method.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6.
    • Close the handle on the iSclack, opening the suction-cup jaws.
  2. iPhone 6 iSclack Opening Procedure: step 2, image 1 of 2 iPhone 6 iSclack Opening Procedure: step 2, image 2 of 2
    • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, just above (but not covering) the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    • If the screen is completely shattered to the point that a suction cup will not stick, use clear packing tape or similar to cover the screen. Sometimes you can even pull up using just the tape without using the suction cup.
  3. iPhone 6 iSclack Opening Procedure: step 3, image 1 of 2 iPhone 6 iSclack Opening Procedure: step 3, image 2 of 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the display cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 8.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 11
All Time: 946
