iPhone 5s Speaker Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 5s Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove the following screws:
    • One 2.9 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • One 3.6 mm Phillips #000 screw
  2. iPhone 5s Speaker Replacement: step 2, image 1 of 2 iPhone 5s Speaker Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to gently lift the speaker from the rear case.
    • Do not attempt to pry the speaker entirely out of the case.
  3. iPhone 5s Speaker Replacement: step 3, image 1 of 3 iPhone 5s Speaker Replacement: step 3, image 2 of 3 iPhone 5s Speaker Replacement: step 3, image 3 of 3
    • The speaker has a small peg that slides into a slot beneath the home button cable socket.
    • Lift the speaker and pull it toward the side of the phone to free this peg from the Lightning connector assembly.
    • Remove the speaker.
Sam Goldheart
465,958 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,288 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 647
