Shop the Holiday Gift Guide
iPhone 5s Display Assembly - Video Tutorial Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
10
All Time:
5,192
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 26
26 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Community-Contributed Guide
Introduction
Go to step 1 ↓
For the official iFixit guide, click here. The guide you are viewing is retained for historical purposes only.
How to disassemble an iPhone 5S and to change / replace the touch screen digitizer glass & LCD display assembly.
Tools
Video Overview
    1. iPhone 5s Display Assembly - Video Tutorial Replacement, Turn off the phone: step 1, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Turn off the phone: step 1, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Turn off the phone: step 1, image 3 of 3
      • Turn off the phone.
      • If the touch screen is not working, press and hold the home button and the power button for 5 seconds.
      Ask FixBot
    2. iPhone 5s Display Assembly - Video Tutorial Replacement, Pentalobe screws: step 2, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Pentalobe screws: step 2, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Pentalobe screws: step 2, image 3 of 3
      • With a pentalobe screwdriver remove the two security screws near to the charging connector.
      • Put the suction cup on the glass and with a cutter carefully lift a little the glass to make a room for the plastic tool.
      • With a plastic pick or other plastic tool separate the screen from the phone but not open it fully.
      Ask FixBot
    3. iPhone 5s Display Assembly - Video Tutorial Replacement, The Home button flex cable: step 3, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, The Home button flex cable: step 3, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, The Home button flex cable: step 3, image 3 of 3
      • Disconnect the Home button flex cable.
      • Up on the connector there is a small metal bracket.
      Ask FixBot
    4. iPhone 5s Display Assembly - Video Tutorial Replacement, The Battery connector: step 4, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, The Battery connector: step 4, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, The Battery connector: step 4, image 3 of 3
      • Remove the two Phillips screws.
      • Remove the metal bracket.
      • Disconnect the battery.
      Ask FixBot
    5. iPhone 5s Display Assembly - Video Tutorial Replacement, Upper bracket: step 5, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Upper bracket: step 5, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Upper bracket: step 5, image 3 of 3
      • The display flex cable connectors bracket is secured by four Phillips screws.
      • Remove them and the remove the bracket.
      Ask FixBot
    6. iPhone 5s Display Assembly - Video Tutorial Replacement, The display flex cables: step 6, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, The display flex cables: step 6, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, The display flex cables: step 6, image 3 of 3
      • Disconnect:
      • The front camera flex cable
      • The LCD flex cable
      • The touch screen flex
      • Now you can remove the display assembly.
      Ask FixBot
    7. iPhone 5s Display Assembly - Video Tutorial Replacement, Display Assembly parts: step 7, image 1 of 1
      • From the old spare part we have to remove and install to the new spare part:
      • Home button assembly
      • Earpiece
      • Front camera and proximity sensor flex cable
      • LCD shield
      Ask FixBot
    8. iPhone 5s Display Assembly - Video Tutorial Replacement, Home button assembly: step 8, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Home button assembly: step 8, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Home button assembly: step 8, image 3 of 3
      • Remove the 3x Phillips screws.
      • Use a plastic tool and gently separate the Home button assembly.
      Ask FixBot
    9. iPhone 5s Display Assembly - Video Tutorial Replacement, Earpiece: step 9, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Earpiece: step 9, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Earpiece: step 9, image 3 of 3
      • The screws are different sizes.
      • Remove the earpiece bracket.
      • Remove the earpiece.
      Ask FixBot
    10. iPhone 5s Display Assembly - Video Tutorial Replacement, Front camera and proximity flex cable.: step 10, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Front camera and proximity flex cable.: step 10, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Front camera and proximity flex cable.: step 10, image 3 of 3
      • Use a plastic tool and gently remove the flex cable.
      • Originally the flex cable is stuck to the LCD shield by a black sticker. Unstuck the sticker or remove the flex cable together with the LCD shield. Do this careful!
      • Inspect the new spare part and install on it all small missing parts from the old spare part (front camera bracket, light sensor bracket, etc.).
      Ask FixBot
    11. iPhone 5s Display Assembly - Video Tutorial Replacement, LCD shield: step 11, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, LCD shield: step 11, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, LCD shield: step 11, image 3 of 3
      • The LCD shield is secured by 5x Philleips screws.
      • This is the final part that we have to remove from the old display assembly.
      Ask FixBot
    12. iPhone 5s Display Assembly - Video Tutorial Replacement, Reassembling: step 12, image 1 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Reassembling: step 12, image 2 of 3 iPhone 5s Display Assembly - Video Tutorial Replacement, Reassembling: step 12, image 3 of 3
      • Start with reassembling:
      • Install the LCD shield with 5x Phillips screws
      • Install the front camera flex and the earpiece with the bracket with two fillips screws (the screws are different).
      • Install the home button assembly - metal bracket and 3x Phillips screws
      • Connect the display assembly flex cables and install the bracket with 4x Phillips screws
      • Connect the battery and install the bracket with two Phillips screws
      • Connect the home button flex and put the small bracket up on it
      • Close the display assembly and and secure it with the two penatalobe screws
      Ask FixBot
12 other people completed this guide.
Author
with
ZFix
197,846 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
2 Guide Comments
The display flex cable connectors bracket is secured by four Phillips screws, but they are diferent and i had read that, if you put in different place , you can make a damaged in the motherboard. Please said how is the right place for any of them, becouse i changed the lcd and appears 5 lines and dont work the digitaizer there. i was trying to cleaning the connectors and still same way.
maxi - Reply Share
you fail to show how you replaced the glass screen that was cracked.
Bob Sacco - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 5,192
