N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide
    1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide, Leaf Spring Switch: step 1, image 1 of 1
      • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
      • Remove the battery door and take the batteries out.
      Ask FixBot
    2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: step 2, image 1 of 3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: step 2, image 2 of 3 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: step 2, image 3 of 3
      • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
      • Lift the side of the blaster off exposing its internal parts.
      Ask FixBot
    3. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: step 3, image 1 of 1
      • Work the trigger to ensure the problem is the switch not making a proper connection.
      • Remove the retaining phillips head 10.2 mm screw below the switch.
      Ask FixBot
    4. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: step 4, image 1 of 1
      • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
      Ask FixBot
Jeffrey Sargeant
354 Reputation
1 Guide authored
Michigan Tech, Team 5-8, Lauer Spring 2014 Member of Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 31
All Time: 2,497
