Nikon D40 Back Cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Nikon D40 Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
      Ask FixBot
    2. Nikon D40 Back Cover Replacement: step 2, image 1 of 2 Nikon D40 Back Cover Replacement: step 2, image 2 of 2
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
      Ask FixBot
    3. Nikon D40 Back Cover Replacement: step 3, image 1 of 1
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
      Ask FixBot
    4. Nikon D40 Back Cover Replacement: step 4, image 1 of 1
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
      Ask FixBot
Gerik Kubiak
327 Reputation
2 Guides authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 22
All Time: 343
