iPhone 5c Logic Board Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPhone 5c Logic Board Replacement, Logic Board: step 1, image 1 of 3 iPhone 5c Logic Board Replacement, Logic Board: step 1, image 2 of 3 iPhone 5c Logic Board Replacement, Logic Board: step 1, image 3 of 3
      • Use a spudger to disconnect the Lightning connector ribbon cable from its socket on the logic board.
      • The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
      Ask FixBot
    2. iPhone 5c Logic Board Replacement: step 2, image 1 of 2 iPhone 5c Logic Board Replacement: step 2, image 2 of 2
      • Flip the Lightning connector cable up out of the way of the logic board.
      Ask FixBot
    3. iPhone 5c Logic Board Replacement: step 3, image 1 of 1
      • Disconnect the lower antenna connector from the base of the logic board.
      Ask FixBot
    4. iPhone 5c Logic Board Replacement: step 4, image 1 of 2 iPhone 5c Logic Board Replacement: step 4, image 2 of 2
      • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
      • Disconnect the rear-facing camera cable connector from its socket on the logic board.
      Ask FixBot
    5. iPhone 5c Logic Board Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
      Ask FixBot
    6. iPhone 5c Logic Board Replacement: step 6, image 1 of 2 iPhone 5c Logic Board Replacement: step 6, image 2 of 2
      • Remove the following screws securing the logic board grounding clip to the rear case:
      • 1.2 mm Phillips #000 in the top side-wall
      • 2.5 mm Phillips #000
      Ask FixBot
    7. iPhone 5c Logic Board Replacement: step 7, image 1 of 1
      • Use tweezers to remove the logic board grounding clip.
      Ask FixBot
    8. iPhone 5c Logic Board Replacement: step 8, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the following screws securing the logic board to the rear case:
      • Two 2.3 mm Phillips screws
      • Three 2.7 mm standoff screws
      • Standoff screws are best removed with a standoff screwdriver or standoff driver bit. A small flathead screwdriver can also do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    9. iPhone 5c Logic Board Replacement: step 9, image 1 of 3 iPhone 5c Logic Board Replacement: step 9, image 2 of 3 iPhone 5c Logic Board Replacement: step 9, image 3 of 3
      • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
      • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
      • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
      Ask FixBot
    10. iPhone 5c Logic Board Replacement: step 10, image 1 of 2 iPhone 5c Logic Board Replacement: step 10, image 2 of 2
      • Flip the logic board up toward the volume control buttons to expose the antenna connector.
      • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
      Ask FixBot
    11. iPhone 5c Logic Board Replacement: step 11, image 1 of 1
      • Disconnect the antenna connector from the back of the logic board.
      Ask FixBot
    12. iPhone 5c Logic Board Replacement: step 12, image 1 of 1
      • Remove the logic board from the rear case.
      Ask FixBot
Andrew Optimus Goldheart
515,900 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 623
