Mac mini Model A1283 Logic Board Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Mac mini Model A1283 Logic Board Replacement, Logic Board: step 1, image 1 of 1
    • Use the flat end of a spudger to pry the power button cable connector up off the logic board.
  2. Mac mini Model A1283 Logic Board Replacement: step 2, image 1 of 1
    • Use the flat end of a spudger to pry the sleep light cable connector up off the logic board.
    • During reassembly, make sure the cable does not come near the lug on the bottom case (shown in green) to avoid damaging the cable.
  3. Mac mini Model A1283 Logic Board Replacement: step 3, image 1 of 1
    • Remove the single T10 Torx lug next to the RAM sockets on the logic board.
  4. Mac mini Model A1283 Logic Board Replacement: step 4, image 1 of 1
    • Use a spudger to lift the free end of the logic board off the bottom housing near the PRAM battery.
  5. Mac mini Model A1283 Logic Board Replacement: step 5, image 1 of 1
    • While slightly lifting the free end of the board pull it away from the port side of the mini, minding any edges that may get caught.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,920
