Shure SM58 XLR Connector Replacement
Views: 20K
View statistics:
Past 24 Hours:
8
Past 7 Days:
45
Past 30 Days:
178
All Time:
19,919
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
The XLR connector is the place where the XLR cable connects to the microphone. If the connector is pulled out, the internal wiring of the microphone can be damaged.
Tools
    1. Shure SM58 XLR Connector Replacement, Connector: step 1, image 1 of 3 Shure SM58 XLR Connector Replacement, Connector: step 1, image 2 of 3 Shure SM58 XLR Connector Replacement, Connector: step 1, image 3 of 3
      • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
      • Make sure you are not holding the microphone connector by the wires.
      • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
      Ask FixBot
    2. Shure SM58 XLR Connector Replacement: step 2, image 1 of 2 Shure SM58 XLR Connector Replacement: step 2, image 2 of 2
      • Hold the microphone connector in one hand and the microphone base in the other.
      • Line up the screw in the connector with the hole in the middle of the microphone.
      • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
      Ask FixBot
    3. Shure SM58 XLR Connector Replacement: step 3, image 1 of 2 Shure SM58 XLR Connector Replacement: step 3, image 2 of 2
      • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
      • Do not push the microphone past this point or the connector may become stuck.
      Ask FixBot
    4. Shure SM58 XLR Connector Replacement: step 4, image 1 of 1
      • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
      Ask FixBot
Following these steps should reinstall the XLR connector back into the microphone.
2 other people completed this guide.
nat coll
868 Reputation
14 Guides authored
Cal Poly, Team 7-53, Forte Fall 2012 Member of Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Members
180 Guides authored
2 Guide Comments
kmusic - Reply Share
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - Reply Share
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 178
All Time: 19,919
