Shop the Holiday Gift Guide
the GEN 2 Wheelchair Tire Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
44
Past 30 Days:
211
All Time:
4,238
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide shows how to remove and replace an inner tube of a tire. This process may difficult he first time it is attempted.
    1. the GEN 2 Wheelchair Tire Replacement, Tire Inner Tube: step 1, image 1 of 3 the GEN 2 Wheelchair Tire Replacement, Tire Inner Tube: step 1, image 2 of 3 the GEN 2 Wheelchair Tire Replacement, Tire Inner Tube: step 1, image 3 of 3
      • Remove the flat tire by loosening and removing the axle nut with a 19 mm wrench.
      • Unscrew the axle bolt with a 19 mm socket wrench.
      • Remove the axle bolt from hole and remove the wheel from the wheelchair.
      Ask FixBot
    2. the GEN 2 Wheelchair Tire Replacement: step 2, image 1 of 2 the GEN 2 Wheelchair Tire Replacement: step 2, image 2 of 2
      • Insert the 19 mm socket wrench between the rubber tire and the metal frame.
      • Any rigid flat object will do for this step.
      • Carefully run the 19 mm socket wrench along the edge of the tire all the way around and bend the wrench down to pop the tire out of the rim.
      • When undoing the tire, be careful using the back of the wrench because the tool can damage the tire tube and or wheel frame.
      • Reach inside the tire and remove the tube from the metal frame.
      • Carefully feed the air valve through the hole in the rim before removing, or you could tear a larger hole in the tire.
      Ask FixBot
    3. the GEN 2 Wheelchair Tire Replacement: step 3, image 1 of 1
      Ask FixBot
    4. the GEN 2 Wheelchair Tire Replacement: step 4, image 1 of 1
      • Before replacing the tube, feel along the tire to check for and remove any objects stuck in the tire.
      • Line up the air valve on the new (partially deflated) tube with the hole on the metal frame.
      • Working all around the tire, carefully push the tube back into place inside the tire.
      • Finally, push the tire back into place on the metal frame and inflate the tire.
      • The tire should be inflated to 50 psi and very hard.
      Ask FixBot
    5. the GEN 2 Wheelchair Tire Replacement: step 5, image 1 of 2 the GEN 2 Wheelchair Tire Replacement: step 5, image 2 of 2
      • Insert the axle bolt into center of rear wheel.
      • Insert the wheel with the axle bolt into the lower back of the frame.
      Ask FixBot
    6. the GEN 2 Wheelchair Tire Replacement: step 6, image 1 of 2 the GEN 2 Wheelchair Tire Replacement: step 6, image 2 of 2
      • Screw the bolt on the outside of the wheel with a 19 mm socket wrench.
      • Screw the nut on the inside of the wheel with a 19 mm wrench.
      Ask FixBot
Author
with
Kali Slaughter
257 Reputation
5 Guides authored
Cal Poly, Team 14-8, Maness Spring 2013 Member of Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 211
All Time: 4,238
