iPhone 4S Dock Connector Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 4S Dock Connector Cable Replacement, Dock Connector Cable: step 1, image 1 of 2 iPhone 4S Dock Connector Cable Replacement, Dock Connector Cable: step 1, image 2 of 2
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.5 mm Phillips screw
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
  2. iPhone 4S Dock Connector Cable Replacement: step 2, image 1 of 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  3. iPhone 4S Dock Connector Cable Replacement: step 3, image 1 of 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  4. iPhone 4S Dock Connector Cable Replacement: step 4, image 1 of 2 iPhone 4S Dock Connector Cable Replacement: step 4, image 2 of 2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,902
