Introduction
Use this guide to replace the metal vibrate/ring switch cover. This guide is not for the electronic portion of the vibrate/ring switch.
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the metal clip covering the antenna connector.
Use the clear plastic pull tab to gently lift the battery out of the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
Remove the SIM card and its holder.
Remove the following two screws:
One 1.2 mm Phillips
One 1.6 mm Phillips
Remove the thin steel dock connector cable cover from the iPhone.
Use an iPod opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
Use a plastic opening tool to pry the lower antenna connector up off its socket on the logic board.
Remove the following five screws securing the Wi-Fi antenna to the logic board:
One 2.3 mm Phillips
Two 1.6 mm Phillips
One 1.4 mm Phillips
One 4.8 mm Phillips
Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
Use an iPod opening tool to carefully lift the rear camera connector up off its socket on the logic board.
Remove the rear camera.
Remove the small circular white sticker (warranty sticker and water indicator) covering the screw near the battery pull tab.
Remove the 2.4 mm Phillips screw that was hidden underneath the sticker.
Use the edge of a plastic opening tool to gently pry the following connectors up and out of their sockets on the logic board:
Digitizer cable (pry from bottom)
LCD cable (pry from bottom)
Headphone jack/volume button cable (pry from top)
Top Microphone/sleep button cable (pry from top)
Front camera cable (pry from top)
Use the edge of a plastic opening tool to lift the thin steel front camera retainer off the front camera.
Remove the front camera retainer.
Remove the following two screws securing the vibrator to the inner frame:
One 6 mm Phillips screw
One 1.4 mm Phillips screw
Remove the vibrator from the inner case.
Use the edge of a plastic opening tool to peel the small strip of black tape off the back of the volume button bracket.
Carefully remove the remaining portion of tape off the small section of ribbon cable near the inside of the bottom volume button.
Remove the five Phillips screws securing the silent and volume button brackets to the outer case.
The screw directly below the silent switch is shorter than the others.
The left screw securing the volume control bracket is longer then the rest.
Grab the headphone jack with a pair of tweezers and remove the assembly from the iPhone, being careful not to rip the thin ribbon cables.
Use the edge of a plastic opening tool to peel the electronic portion of the silent switch off its metal bracket.
Transfer the bracket to the new silent switch.
Repeat this procedure to peel the metal volume button bracket off the electronic portion of the volume buttons.
Transfer the volume button bracket to the new volume buttons.
