Installing iPhone 4 Verizon Speaker Enclosure Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing iPhone 4 Verizon Speaker Enclosure Assembly, Speaker Enclosure Assembly: step 1, image 1 of 2 Installing iPhone 4 Verizon Speaker Enclosure Assembly, Speaker Enclosure Assembly: step 1, image 2 of 2
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable cover to the logic board.
    • Remove the metal dock connector cable cover.
  2. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 2, image 1 of 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  3. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 3, image 1 of 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  4. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 4, image 1 of 2 Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 4, image 2 of 2
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
    • When reinstalling the pressure contact, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
  5. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 5, image 1 of 2 Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 5, image 2 of 2
    • Use the edge of a plastic opening tool to pry the Wi-Fi antenna cable up from its socket on the logic board.
    • De-route the Wi-Fi antenna cable out from under the metal fingers attached to the logic board.
  6. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 6, image 1 of 1
    • Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
  7. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 7, image 1 of 1
    • Remove the small black spacer that was under the Phillips screw near the vibrator.
  8. Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 8, image 1 of 3 Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 8, image 2 of 3 Installing iPhone 4 Verizon Speaker Enclosure Assembly: step 8, image 3 of 3
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 697
