TiVo Series 2 TCD24008A Motherboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
85
All Time:
1,597
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Motherboard contains all the 'brains' of the device. In case this component needs to be replaced, this guide will walk you through the installation of the motherboard.
Tools
    1. TiVo Series 2 TCD24008A Motherboard Replacement, Cover: step 1, image 1 of 1
      • Unscrew the five 0.31 inch T-9 screws on the back cover.
      Ask FixBot
    2. TiVo Series 2 TCD24008A Motherboard Replacement: step 2, image 1 of 1
      • Slide the cover towards the back until it is no longer under the front cover.
      Ask FixBot
    3. TiVo Series 2 TCD24008A Motherboard Replacement: step 3, image 1 of 1
      • Lift the cover up and off the device.
      Ask FixBot
    1. TiVo Series 2 TCD24008A Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Unscrew the 0.31 inch T-9 size screw on the back panel
      • Unscrew the two 0.59 inch T-8 size screws on the back panel
      Ask FixBot
    2. TiVo Series 2 TCD24008A Motherboard Replacement: step 5, image 1 of 1
      • Unplug the fan from the motherboard by gently pulling up on the red plug.
      Ask FixBot
    3. TiVo Series 2 TCD24008A Motherboard Replacement: step 6, image 1 of 1
      • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
      Ask FixBot
    4. TiVo Series 2 TCD24008A Motherboard Replacement: step 7, image 1 of 1
      • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
      Ask FixBot
    5. TiVo Series 2 TCD24008A Motherboard Replacement: step 8, image 1 of 1
      • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
      Ask FixBot
    6. TiVo Series 2 TCD24008A Motherboard Replacement: step 9, image 1 of 2 TiVo Series 2 TCD24008A Motherboard Replacement: step 9, image 2 of 2
      • Locate the four metal tabs on the motherboard.
      • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
      • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
      Ask FixBot
    7. TiVo Series 2 TCD24008A Motherboard Replacement: step 10, image 1 of 1
      • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
      Ask FixBot
    8. TiVo Series 2 TCD24008A Motherboard Replacement: step 11, image 1 of 2 TiVo Series 2 TCD24008A Motherboard Replacement: step 11, image 2 of 2
      • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
      • Pull up and away from the back panel so all of the cable inputs slip through the casing.
      Ask FixBot
Cody Hunter
46 Reputation
2 Guides authored
Cal Poly, Team 5-33, Amido Fall 2011 Member of Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 85
All Time: 1,597
