Installing iPhone 3GS Proximity Sensor Ribbon
  1. Installing iPhone 3GS Proximity Sensor Ribbon, Proximity Sensor Ribbon: step 1, image 1 of 1
    • Remove the screw that holds this bracket in and put it in a safe place.
  2. Installing iPhone 3GS Proximity Sensor Ribbon: step 2, image 1 of 1
    • Use an automotive pick tool to lift the bracket up on the side of where the speaker lies. Slight upward pressure, do not force or pry.
  3. Installing iPhone 3GS Proximity Sensor Ribbon: step 3, image 1 of 1
    • Do the same with the other side and on the bottom of the bracket. This is held in with tension on fingers that clip into the screen midframe.
  4. Installing iPhone 3GS Proximity Sensor Ribbon: step 4, image 1 of 1
    • Once the bracket is loose, you can pull it up carefully maneuvering it up and around the LCD and digitizer connectors.
  5. Installing iPhone 3GS Proximity Sensor Ribbon: step 5, image 1 of 1
    • Peel the old ribbon from the bracket, note the orientation.
  6. Installing iPhone 3GS Proximity Sensor Ribbon: step 6, image 1 of 1
    • Peel off the adhesive backing protectors from the new ribbon, and line up the holes in the ribbon with the ones on the bracket as so.
  7. Installing iPhone 3GS Proximity Sensor Ribbon: step 7, image 1 of 1
    • Use a small screwdriver's shaft to conform the new ribbon to the bracket's contour. Light pressure is only needed.
    • At the top of the ribbon, note that there are two small holes. Align them with the two holes in the metal piece for a perfect fit.
  8. Installing iPhone 3GS Proximity Sensor Ribbon: step 8, image 1 of 1
    • Lift the digitizer and LCD connectors and snap in the bracket/ribbon combo to finish it off.
hectordtruong
7,414 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 91,697
